signal quality questions | SatelliteGuys.US
vassho
71
setting up one of my receivers to my BUD blind scanning my KU Birds
once all is scanned and channels are downloaded I am always getting a few channels that the signal quality is jumping from 10 to 99% as it wont lock on
I say this is happening for about 5% of my channels the rest come in strong no signal quality issues and this is happening on almost every sat a few channels with the signal quality jumping around not locking in
any ideas
From other posting I believe your using a C/KU feedhorn, if correct does this problem always happen on the same channels and are they H or V polarity. Because my first guess might be your servo motor having issue not locking in correctly.
Satellite Real Estate and the future of FTA
4x1 Diseqc switch blinks in and out when I hook up all LNBs.
