Signal on Tailgater | SatelliteGuys.US
Signal on Tailgater
ezriser
243
2
THE SOUTH EAST
Hope this is not a dumb question. Is there a way to check the signal at the 211/wally with a sat buddy? (trying to figure out if it is the receiver or tailgater)
I don't believe that's going to work since the tailgater has a board that is used in conjunction with the software of the 211 and wallys..What problem are you having?
Something seems off here..When I had a tailgater once you plug in the receiver and it boots up the screen ask you your location and once the info is entered it will scan for the three satellites..110,119&129.in other words its doing a checkswitch.You never mentioned that you have the 129 so make sure you actually do have a clear line of site..
Reactions: charlesrshell
This guy had bought his tailgater 4 in 2017. When the tailgater was swapped with another one, It found all 3 sats. So it was the tailgater. Thanks for the help
Reactions: TheKrell
Another Univision dispute brewing?
DISH Anywhere problem?
