Signal Loss on Satellite Input 2??? | SatelliteGuys.US
diitto
108
Hi, I was told the HR20's I had that were stored in my attic (DTV did not want them back three years ago when we switched to Genie) were SWM compatible so if I could get DTV to reactivate them I should be able to replace my dead HR34 Genie with one of these older HR20's, at least to get that TV up and running. DTV DID reactivate them for me and now I am trying to get one to start. I only have a signal in Sat 1 as this is a SWM setup. And surely these HR20's could run with just a single cable on Sat 1. But it was 75% along the way of loading the Sat data when it said "771-Signal loss on Satellite In 2. Press SELECT for options" and none of those options are useful. Why does it need a signal on Sat 2??? I used to run these two input DVR's with only one input if I recall. And the HR22 we have up and running (it was the 3rd TV setup along with the now broken HR34 Genie and its Genie Mini in another room) has been running fine for 3 years with only a single SWM input.
Any help??? thanks...
As I remember the HR20 won't detect SWM, you have to go through sat setip and tell it it is connected to an SWM LNB.
Reactions: Jimbo and harshness
Question regarding Directv local subchannels l
Want a new HR54
