sig strength 103b | SatelliteGuys.US
sig strength 103b
menos1
4
colonial beach, va
Hey guys, my first post. Great forum. I have a slimline 5lnb dish, my signal strength on the 101, 110 and 119 are in the mid to upper 90's. However, the 103b is in the low to mid 80's and goes out during moderate rain. Would think that since 103b is between 101 and 1 I would be aligned correctly. Have the H20-600 no switch and located in Colonial Beach VA. mid-way between D.C. and Richmond. Any ideas/suggestions? Think I need a re-alignment?? Thanks. GO PATRIOTS!!!!!!
Re alignment is what I would do. Make sure you line of sight is clear. It doen't take much to screw with you signal.
Despite your being a Patriot fan, I will answer your question! :eek: Your numbers on 103b are a bit low, not terrible, but you should have some in the 90's. It does sound like you need a realignment.
How dare you say Go Patriots in Redskin territory. Time to make a call to all the people in King George County.
HD net lawsuit settled
H20-100 fixed....HD now default
