monoprice.comwhere can i buy a cheap one??? because i went to best buy and they were like 50 and 60
:haha:haha:hahaYeah, the sound quality over components is really lacking.
Hi my hd dvr is connected trough component cables the image is pretty good, but i was wondering if i buy an hdmi cable would the image be waaay better?? or would it be just a little bit better??
It may not be better at all. Most people who I have helped hook up their ViP DVR's prefer component. Besides, HDMI has been shown to be problematic with Dish receivers and even the tiniest movement of the connector can disrupt/disable your connection/viewing.
If you're considering HDMI, keep this in mind. If you run HDMI to your TV, then digital sound to your stereo, you might not get the right sound. Many TV's do not pass through the sound as they receive it through HDMI, instead downgrading it to digital stereo. If your TV does this, then you'll want to run an optical cable from your Dish to your stereo receiver for the sound, and just use the video portion on your TV.
Yeah, sorry, left out that option. I have an Onkyo TX-SR606 receiver with 4 HDMI inputs and one output, and that's exactly what I do, the receiver takes care of switching the inputs (Dish, PS3, Xbox 360, and one that is currently unused).Or you could just run everything through your AV receiver then on to your TV (if you have a good enough receiver).
That said, my upconverting DVD player requires an HDMI connection to do its voodoo -- and it does it well enough that I'm staying away from Blu-Ray.
Limited time offer
