Sherwood AV Reciever Codes | SatelliteGuys.US
Like Matt said....
I have a different model Sherwood for which the only Sherwood code supplied for a 21.0 remote in the 722K manual did not work. Did a scan and came up with 2-743.
Well, that will cost you at least 100+ Get at 21.0 for about $20.00
He might not even need that, if he uses the code I gave, or does the scan.
I went through a scan 2 different times... still haven't got it to work the av receiver.. I may try the 21.0 thats sounds interesting. So will this remote would basically be a replacement for my 6.3?
RG6
My 222 does not show the same "info" as my 622
