shaw direct satellite | SatelliteGuys.US
Actually Yes. Take the small screw out of the bottom of the lnb and it will slide right on the DTV Slimline Dish with the spring load latch on the arm. Works perfectly for Shawdirect.
I had one shipped to me in Canada to test. Can take a pic and post if anyone desire's?
DSC00351.JPGDSC00350.JPGDSC00349.JPG Here ya go, Finally got home today while it was still light out. ;)
Satellite 2.jpgSatellite 1.jpgCan anyone tell me what the skew any elevation should be for mesa.AZ I have the old 60 dish and dsr 530 receiver and I am missing channel even after refreshing on the web site . I have receiving at 62 and 61 and Ecb 299 is 6.1 and 350 is 7.2
mjlafleur: although the 75cm dish has a different LNB than the 60 cm, as long as you keep the same type of LNB for the dish (Ku or xKu), you won't have to call
NO. Only the Xku with a 600 series receiver picks up the new G1 mainly in Canada. It does work a bit past the border. Just read someone is getting it in Portland Oregon with a 75Xku dish.
I have ku lnb 60 if I change to ku 75 will I get this new G satellite channel
DirecTV Slimline dish with Shaw triple LNB?
Need Dish Alignment Advice
