SG9120B | SatelliteGuys.US
SG9120B
icu1954
275
lower alabama
hi guys,i need a little help on getting my SG9120B set up on the arc,what i mean is you know how instructions are when they come with a product,about as useless as the paper it is printed on.I have a 3 foot dish it is being mounted on and my stb is a orasat 5.0 with (DISEqC 1.2) with motor/goto 0 i would not have any trouble mounting it,i want to know a few tricks on getting it align on the arc.Also would i have to manually align every satellite that i program into my stb by hand or would it do it automatically...need your help guys...thanks for this forum..you have never let me down yet.:up
I'm not familiar with your receiver, but did install a new sg9120b a few weeks ago.
I ended up using a circular LNB and found the Dish, Nimiqs and other circular sats from 61° to 119°, then switched to a linear LNB and fine tuned the arc in. You can slowly move the circular LNB around in front of the dish to catch signal - make sure you have an active TP selected - then zero in the dish for maximum signal.
The declination instructions in the "manual" - the one that came with mine isn't much bigger than a business card - are off by 10°, they should be 30° minus the declination angle for your latitude.
So far the motor works great. Hopefully it does better than the sg2100 did when winter sets in.
Fashion One Channel on 97.0W Gone ?
I-Link 9500 HD
