SG2100 HH Motor back in stock | SatelliteGuys.US
Are there plenty of these still around? I wonder if I should buy a few. I don't like what I've been reading about the new, 2-button version...
A few years back, the SG-2100's weakness was the supplied square U-bolts to attach the motor bracket to the pole. Back then, the U-bolts were made of porous metal, which stripped VERY easily when the bolts were tightened beyond hand-tight. They have since replaced the porous metal bolts with ones made with a better quality metal.
When they designed the SG 6000 they copied the Stab H H bracket and clamp design. That design works very well and does not distort the bracket.
You can search for Stogies improvement to the SG 2100 bracket.
New here.. need some help please
Help Figuring Out FTA For DTV 3LNB For AMC4 101w
