Setup Question | SatelliteGuys.US
Setup Question
satellitekid
13
hi all
i am setting up WINEGARD 1 METER DISH WITH A GEOSATPRO 120 MOTOR
WITH A GEOSATPRO 120 55 M M PIPE ADAPTER.
i put a pipe in the ground how long do i have to wait for the CONCRETE
TO SETUP.I LIKE FTA CHANNELS.
Until its hard ;)
The longer you can leave it the better, overnight would be best.
Check the bag that it came in for exact curing directions taking into account the temperature where you are!
Good Luck!
Hope you put a bolt or something through the pole to stop it rotating under wind load!
Also a good idea to fill the pole to the top with cement to stop any flex in the pole caused by the weight of the dish and motor........
Also a good idea to check to be sure the pole is still level with an angle finder from time to time while the concrete is setting, as wind and pole weight can shift the pole so it is not plumb.
Adding a Circular LNB
Was this a Deal?
