Setting up Fortec 100 cm Dish SG 2100 motor & Invacom LNB | SatelliteGuys.US
jsattv
1,061
8
I am a newbie & considering purchasing a Fortec 1 meter dish with a SG2100 Motor and Invacom LNB at a local Winnipeg Fortec dealer. I currently have a subscription to Bell on a 9200 receiver. Considering a Coolsat or other FTA receiver, for the Fortec motorized dish. Are there good setup instructions on how line up dish and motor on a peaked bungalow roof? Or would a 10 foot pole be a better idea for mounting?
What channels and satellites are you aiming for?
Putting a ku dish on a 10' pole is a bad idea (IMO) if the dish moves just a few millimeters you will loose the picture! I HATE putting satellite dish on a roof, but that may be your BEST option.
Most Invacoms are Universal (L.O. = 9750-10600)
But the Invacom QPH-031 is a standard on the linear side so the L.O. will be 10750
IA-5 @ 97ºw is your TRUE SOUTH satellite.
Have a look at the below, the elevation angles are WITHOUT a motor.........
Code:
          Latitude 50° 0.000'N Longitude 97° 0.000'W
                       Sat Name Sat Lng Az(t) Az(m)    El  Skew
                       Amos 1/2    4.0W 267.7 263.3 -10.5 -40.0
                Atlantic Bird 3    5.0W 268.5 264.1  -9.9 -40.0
                Nilesat 101/102    7.0W  90.0  85.6  -8.6 -40.0
     Telecom 2D/Atlantic Bird 2    8.0W  90.8  86.4  -8.0 -40.0
                     Express A3   11.0W  93.1  88.7  -6.1 -39.9
                 (C) Express A4   14.0W  95.4  91.0  -4.2 -39.8
                     Telstar 12   15.0W  96.1  91.7  -3.6 -39.7
                   Intelsat 901   18.0W  98.5  94.1  -1.7 -39.5
                          NSS 7   22.0W 101.6  97.2   0.9 -39.0
                   Intelsat 905   24.5W 103.6  99.2   2.5 -38.7
                   Intelsat 907   27.5W 106.0 101.6   4.3 -38.2
                  Hispasat 1C/D   30.0W 108.0 103.6   5.9 -37.7
                   Intelsat 801   31.5W 109.2 104.8   6.8 -37.4
                   Intelsat 903   34.5W 111.7 107.3   8.7 -36.7
                     (C) AMC 12   37.5W 114.3 109.9  10.5 -35.9
                        NSS 806   40.5W 116.9 112.5  12.3 -35.0
                      Pas 3R/6B   43.0W 119.1 114.7  13.7 -34.2
                         Pas 1R   45.0W 120.9 116.5  14.9 -33.5
               (C) Intelsat 705   50.0W 125.5 121.1  17.7 -31.5
                   Intelsat 707   53.0W 128.4 124.0  19.3 -30.2
               (C) Intelsat 805   55.5W 130.9 126.5  20.6 -29.1
                          Pas 9   58.0W 133.4 129.0  21.9 -27.8
                       Amazonas   61.0W 136.5 132.1  23.4 -26.3
                     EchoStar 3   61.5W 137.0 132.6  23.6 -26.0
                      Rainbow 1   61.5W 137.0 132.6  23.6 -26.0
               Estrela do Sul 1   63.0W 138.6 134.2  24.3 -25.1
               (C) Brasilsat B2   65.0W 140.8 136.4  25.2 -24.0
               (C) Brasilsat B1   70.0W 146.4 142.0  27.2 -20.9
                       Nahuel 1   72.0W 148.7 144.3  28.0 -19.5
                      DirecTV 1   72.5W 149.3 144.8  28.1 -19.2
                          AMC 6   72.0W 148.7 144.3  28.0 -19.5
                          SBS 6   74.0W 151.0 146.6  28.6 -18.2
                 Echostar/G4R 4   77.0W 154.6 150.2  29.6 -16.0
                          AMC 5   79.0W 157.0 152.6  30.2 -14.5
                      Nimiq 2/3   82.0W 160.7 156.3  30.9 -12.3
                          AMC-9   83.0W 162.0 157.6  31.1 -11.5
                (C)Brasilsat B3   84.0W 163.2 158.8  31.4 -10.7
                          AMC 2   85.0W 164.5 160.1  31.6  -9.9
                          AMC 3   87.0W 167.0 162.6  31.9  -8.3
                           IA-8   89.0W 169.6 165.2  32.2  -6.7
                      Galaxy 11   91.0W 172.2 167.8  32.4  -5.0
                     Nimiq 1/4i   91.0W 172.2 167.8  32.4  -5.0
                (C)Brasilsat B4   92.0W 173.5 169.1  32.5  -4.2
                           IA-6   93.0W 174.8 170.4  32.6  -3.3
                      Galaxy 3C   95.0W 177.4 173.0  32.7  -1.7
                           IA-5   97.0W 180.0 175.6  32.7   0.0
                      Galaxy 16   99.0W 182.6 178.2  32.7   1.7
                     Spaceway 2   99.2W 182.9 178.5  32.6   1.8
                DirecTV 1R/4S/8  101.0W 185.2 180.8  32.6   3.3
                          AMC 4  101.0W 185.2 180.8  32.6   3.3
                     Spaceway 1  103.0W 187.8 183.4  32.4   5.0
                          AMC 1  103.0W 187.8 183.4  32.4   5.0
                         AMC 15  105.0W 190.4 186.0  32.2   6.7
                       Anik F1R  107.3W 193.3 188.9  31.8   8.5
                     (C) AnikF1  107.3W 193.3 188.9  31.8   8.5
                      DirecTV 5  109.5W 196.1 191.7  31.5  10.3
                  EchoStar 8/10  110.0W 196.8 192.4  31.4  10.7
                        Anik F2  111.1W 198.2 193.7  31.1  11.6
                       SatMex 6  113.0W 200.5 196.1  30.7  13.0
                  Solidaridad 2  114.9W 202.9 198.5  30.2  14.5
                       SatMex 5  116.8W 205.2 200.8  29.7  15.9
                         AMC-16  119.0W 207.8 203.4  29.0  17.4
                     DirecTV 7s  119.0W 207.8 203.4  29.0  17.4
                     EchoStar 7  119.0W 207.8 203.4  29.0  17.4
          EchoStar 9/Telstar 13  121.0W 210.2 205.8  28.3  18.8
                     Galaxy 10R  123.0W 212.5 208.1  27.6  20.2
                  (C) Galaxy 14  125.0W 214.8 210.4  26.8  21.5
                   Galaxy 13/H1  127.0W 217.0 212.6  26.0  22.8
 Intelsat Americas 7/Echostar 5  129.0W 219.2 214.8  25.2  24.0
                     (C) AMC 11  131.0W 221.4 217.0  24.3  25.1
                  (C) Galaxy 15  133.0W 223.5 219.1  23.4  26.3
                     (C) AMC 10  135.0W 225.6 221.2  22.4  27.3
                      (C) AMC 7  137.0W 227.6 223.2  21.4  28.3
                      (C) AMC 8  139.0W 229.6 225.2  20.4  29.3
                   EchoStar 1/2  148.0W 238.2 233.8  15.5  33.1
        Satellite Finder is (c) Copyright 2004, P. Lutus
When you do add the motor........
The motor elevation = 40º
Dish (When on motor) elevation = 23º
Here is a good strong transponder to use when pointing the dish, watch ONLY for signal QUALITY!
DFreq. = 12084
pol. V
SR. 22002
Setting up Fortec 100 cm Dish on Sg2100 motor & Invacom LNB
Thats a good question, don't know. Want to do it as a hobby and general interest in other sat feeds, besides my subscription sat. Is there enough info out there to make it worthwhile? Ie. I see guys here post about the Tube - I think on Sat 97. If I can ask what is the Tube? And is this a long installation since winter is almost here?
Takes me 2 hours to install a motorized system, but your best taking your time and enjoying the setup. It was 70º here in MN. yesterday so you should have just enough time to get the dish installed.
The Tube is an all music video channel, unfortunately is now only on C-Band satellite @ 87ºw (AMC-3) With C-band you will need at least a 6' (1.8m) dish!
Thank you for the info. It's cold up here. - 10 degrees (celcius) today and not much better for weekend. If it takes you 2 hours, it will take us 4 hrs minimum, since not having done this before. When we setup up the motor on the dish do we use sg2100 satcalculator.freehostia coordinates for my street in Winnipeg, then first set up for sat 97?? Is there a guide or info to help with choose which satellites to select? Being new to this area how can I find out what is of interest on the satellites such as 97 etc?
IA-5 is your TRUE south satellite, so thats the satellite you would be aiming at when setting up the motor.
Have a look here for help with the setup of the motor...........
http://www.satelliteguys.us/showthread.php?t=50257
Its sometimes an idea to find the satellite and store it (With above posted angles) without the motor first.
Thanks for your great help PSB. Especially the links. Took the plunge and bought the 100 cm dish, SG 2100 motor and Invacom LNB today. Ran into a problem trying to get the U square bolts inside the Azimuth Bracket. They hold the pole to the Dish. There is no way I can see these Bolts fitting inside, unless the Azimuth Bracket is bent out in a vise. No way can I get hold of Fortec Star help this weekend. Do you know if anyone can help??
Heavy Duty Mount for this 100 cm dish - $20.00. The salesperson showed me a really heavy duty OPTIONAL roof mount for this dish. Its a thick curved pipe that looks like the mounting for my Bell Subscription Dish. - only much bigger (thicker pipe) and sturdier. I was wondering if others have seen it, and is it worth purchasing? It sure looks like it could stand up to the wind.
Your reply would be appreciated.
True South Sat
Fortec classic & Large LCD's
