set up problem | SatelliteGuys.US
set up problem
yanyo
ok im having problems getting signal on my system, this is what i have:
coolsat 5000 platinum
Invacom QPH-031
fortec star 36"
stab HH90 motor
my info:
elevation 44
azimuth 233(minus magnetic deviation comes to 233-5=228 degrees magnetic south)
latitude 28
longitude 80
im pointing my dish using a compass to 228 degrees, trying to get my true south satellite which 82.0°W Nimiq 2.
what im doing wrong??? i cant get any signal higher than 7%
any help will be appreciated..
What channels on Nimiq 2 are you trying to get?
Send me a PM and let me know and I will reopen the thread!
OK Thanks for the PM. (Stating he is using 82w for set up only)
Welcome to the satelliteGuys.US FTA forum!
If you are using Nimiq 2 as your true south make sure to use one of the outputs marked C from the QPH-031 LNBF. Remove any switches you may be using for now.
Make sure you have the L.O. set to 11250 in the antenna set up screen.
Its a good idea to remove the motor for now and find/store signals from your true south satellite before adding it back to the set up.
(When you get round to using the L side of the LNBF make sure to set the L.O. to 10750 in the antenna setup screen)
looking for help!!
