SES1 101W | SatelliteGuys.US
SES1 101W
skihoodoo
SatelliteGuys Guru
148
10
PERSHING COUNTY NV
Is anyone else having problems with SES1 at the 101w location i think i have a bad lnb but am not sure as my sat it pointed at 97.w as well old glorystar system lnb is about 4 years old
None here either. Can you explain your symptoms in better detail?
no problems on my 22k side of my combiner(97w) signal is 90% for my two lnb glory star system that i got in 2010
on the side that is looking at 101w no signal period just started yesterday after a bunch of rain no rain in the area right now and its still down will be looking at replacing both lnbs at the same time
I would check all coax connections first.
I've seen where the gaskets on the feed, LNB and right angle, shrink(or are the wrong size). Lets water into the waveguide. Kills signal. If that's OK - Check the coax first. Second would to bypass the switch(take it out of the equation), Then the LNBs.
Alternative satellite service provider to DISH and DTV??
SES 2 87.0W Programing
