SES 2 at 87.0°W | SatelliteGuys.US
SES 2 at 87.0°W
is it possibe to receive se2 at 87.0 w with amiko mini hd reciever a bsc42 lnb and a 7.5 mesh bud
It depends on how well your dish is tweaked but I think you should receive that sat. The Luken mux used to be hard to get but they bumped the power up a while back and on my 8' mesh I'm getting 80Q. Also, getting Pursuit and a few others although not as high on the Q.
My Amiko NanoHD gets the RTV mux (4000 H) on 87W fine with a 6 ft Fortec dish that has a BSC-621 on it. Quality is 65 to 70.
The A3 connected to the 8 ft dish has a quality of 85 on the same channel but that dish has Chaparral LNBs on it.
The Mini HD and a 7½ ft dish should be OK.
BTW, I'm located in central NC.
The Mini HD SE will tune it fine, it is the the dish you have to worry about. Having said that though, since they increased their power you should be ok. :)
Mounting a pole mast without concrete
thanks
