Sept 13th Uplink Report... | SatelliteGuys.US
Scott Greczkowski
Welcome HOME!
Staff member
HERE TO HELP YOU!
Cutting Edge
Sep 7, 2003
103,775
29,677
Newington, CT
The SatelliteGuys.US Uplink Activity Report - 09/13/2006 - 84 changes
Uplink Comparison Range: 09/12/2006 12:56P - 09/13/2006 11:57A
224 - SAH removed from 110.0W TP 3
299 - REELZ added to 119.0W TP 15 (Not Available)
659 - DUBSP - 148.0W TP 29 changed to Available
659 - DUBSP - 61.5W TP 31 changed to Available
667 - K TV added to 148.0W TP 25 (Not Available)
667 - K TV added to 61.5W TP 12 (Not Available)
674 - INDMU - 148.0W TP 27 changed to Available
674 - INDMU - 61.5W TP 16 changed to Available
678 - INDVI - 148.0W TP 27 changed to Available
678 - INDVI - 61.5W TP 16 changed to Available
716 - VIDIT - 148.0W TP 1 changed to Available
716 - VIDIT - 61.5W TP 6 changed to Available
717 - LEOWD - 148.0W TP 9 changed to Available
717 - LEOWD - 61.5W TP 8 changed to Available
908 - RAD60 - 148.0W TP 9 changed to Available
908 - RAD60 - 61.5W TP 8 changed to Available
909 - RADIT - 148.0W TP 1 changed to Available
909 - RADIT - 61.5W TP 6 changed to Available
5759 - TWCTS - 119.0W TP 6 changed to Available
5781 - TEMPN removed from 148.0W TP 23
5837 - SDTS1 renamed to MP201 (NA)
5837 - SDTS1 moved from 148.0W TP 20 to 148.0W TP 20 (NA)
5838 - SDTS2 renamed to MP202 (NA)
5838 - SDTS2 moved from 148.0W TP 20 to 148.0W TP 20 (NA)
5839 - SDTS3 renamed to MP203 (NA)
5839 - SDTS3 moved from 148.0W TP 20 to 148.0W TP 20 (NA)
5843 - NTST1 renamed to MP311 (NA)
5843 - NTST1 moved from 148.0W TP 31 to 148.0W TP 31 (NA)
5844 - NTST2 renamed to MP312 (NA)
5844 - NTST2 moved from 148.0W TP 31 to 148.0W TP 31 (NA)
5849 - SMP41 renamed to MP051 (NA)
5849 - SMP41 moved from 148.0W TP 5 to 148.0W TP 5 (NA)
5850 - SMP42 renamed to MP052 (NA)
5850 - SMP42 moved from 148.0W TP 5 to 148.0W TP 5 (NA)
5851 - SMP43 renamed to MP313 (NA)
5851 - SMP43 moved from 148.0W TP 31 to 148.0W TP 31 (NA)
5852 - SMP21 renamed to MP314 (NA)
5852 - SMP21 moved from 148.0W TP 31 to 148.0W TP 31 (NA)
5853 - SDTS4 renamed to MP204 (NA)
5853 - SDTS4 moved from 148.0W TP 20 to 148.0W TP 20 (NA)
5857 - HMP41 renamed to MP053 (NA)
5857 - HMP41 moved from 148.0W TP 5 to 148.0W TP 5 (NA)
5858 - HMP42 renamed to MP054 (NA)
5858 - HMP42 moved from 148.0W TP 5 to 148.0W TP 5 (NA)
5859 - SMP44 renamed to MP055 (NA)
5859 - SMP44 moved from 148.0W TP 5 to 148.0W TP 5 (NA)
5881 - MP056 added to 148.0W TP 5 (Not Available)
5882 - MP057 added to 148.0W TP 5 (Not Available)
5883 - MP315 added to 148.0W TP 31 (Not Available)
5884 - MP316 added to 148.0W TP 31 (Not Available)
5885 - MP317 added to 148.0W TP 31 (Not Available)
5886 - MP205 added to 148.0W TP 20 (Not Available)
5887 - MP206 added to 148.0W TP 20 (Not Available)
5888 - MP207 added to 148.0W TP 20 (Not Available)
7270 - WUPN renamed to WMYV (A)
7307 - KPMC added to 110.0W TP 25 (Not Available)
7630 - WSTQ - 110.0W TP 4 changed to Available
7738 - WHCT added to 119.0W TP 3 (Not Available)
8134 - WCWB renamed to WPMY (A)
8184 - WBSC renamed to WMYA (A)
8343 - WHSV added to 129.0W TP 16 (Not Available)
8344 - WVPT added to 119.0W TP 3 (Not Available)
8474 - KRRT renamed to KMYS (A)
8614 - KTWB renamed to KMYQ (A)
8872 - WWHB added to 119.0W TP 1 (Not Available)
8925 - KTFO renamed to KMYT (A)
8977 - KMSG added to 110.0W TP 4 (Not Available)
9034 - KVWB renamed to KVMY (A)
9070 - KXTU - 110.0W TP 4 changed to Available
9192 - KMCE added to 110.0W TP 23 (Not Available)
9385 - WRIC moved from 105.0W TP 7 to 110.0W TP 31 (A)
9386 - WTVR moved from 105.0W TP 7 to 110.0W TP 31 (A)
9387 - WWBT moved from 105.0W TP 7 to 110.0W TP 31 (A)
9388 - WRLH moved from 105.0W TP 7 to 110.0W TP 31 (A)
9390 - WUPV moved from 105.0W TP 7 to 110.0W TP 23 (A)
9391 - WCVE moved from 105.0W TP 7 to 110.0W TP 23 (A)
9392 - WCVW moved from 105.0W TP 7 to 110.0W TP 23 (A)
Channels in the system: 3026
(A) = Available
(NA) = Not Available
I was expecting more activity, so I will keep on checking. :)
9385 - WRIC removed from 105.0W TP 7
9386 - WTVR removed from 105.0W TP 7
9387 - WWBT removed from 105.0W TP 7
9388 - WRLH removed from 105.0W TP 7
9390 - WUPV removed from 105.0W TP 7
9391 - WCVE removed from 105.0W TP 7
9392 - WCVW removed from 105.0W TP 7
(A) = Available
Time to work on the output of the uplink tool again. For some reason it's showing the 9385-9392's as removed. Actually they only removed them from 105W.
EDIT: Removed all the test channel renames. Fixed the 105W removals.
As I posted in the INHD Thread in our HD area I am hoping for IN HD and the HD RSNS today, however as they have done in the past (CES) they may have had the new channels showing at the booth but have not made them yet available to the public.
The floor to CEDIA does not open to the press for a few more hours, so no word yet of whats going on at the Dish Network booth.
Smith said:
Digiblur, if those double spacing could be removed ; when is more then 20 updates, then the list will be better read with no spacing.
I manually edited the above report. We will see how the folks like it....
As always, thanks for your input.
ekans said:
I believe KTV is a Soth Asian Tamil Channel (from India) that is being moved from 121 to 148.
I just can't make up my mind which I want most - the Tamil Channel or a Korean karoke channel!!
Now, who would want InHD or some sports channels when you could have those above???
Someone MUST be kidding!! :p
--Doug
JohnH said:
Your comparison clock is not correct.
Works just fine.....
The SatelliteGuys.US Uplink Activity Report - 09/13/2006 - 0 changes
Uplink Comparison Range: 09/13/2006 11:57A - 09/13/2006 01:40P
(A) = Available
--Doug
I can't agree more, except maybe it's Korean karoke.
If they are going to add the channels it should be within the next 30 minutes or so. They have been adding channels around 5 pm eastern(at least the last few channel additions).
drsiebling said:
So much for 5 PM Eastern. 6 PM Eastern? Anyone? Anyone?
The SatelliteGuys.US Uplink Activity Report - 09/13/2006 - 2 changes
Uplink Comparison Range: 09/13/2006 11:57A - 09/13/2006 06:20P
667 - K TV - 148.0W TP 25 changed to Available
667 - K TV - 61.5W TP 12 changed to Available
(A) = Available
Transponders, Encoders, Codecs?
Why phone connection is required for VIP and/or dual-turner receiver?
