Select on 622 | SatelliteGuys.US
Select on 622
JTDeel
13
Is there a setting that you can turn off on the 622 so when you turn off the rec that you dont have to hit select after you turn the rec back on?
JT
Get a Harmony remote. The Harmony 622 PVR programming takes care of that for you. Other universal remotes probably do that, too. When you turn your system off with the 622 remote, the 622 isn't turned off - it just goes into sleep mode on its own schedule and you have to hit select to wake it up.
211 Capabilities
622 keeps rebooting by its self.
