securing cable from dish ? | SatelliteGuys.US
bnewt
1,486
548
Shepherdsville, Ky
I need a little help in determining the best way to secure/hide the cable from the satellite dish into the house
For years I had the cable running down the chimney to the roof line and then down a corner of the deck as it enters the house.
This was run in conjunction with the antenna cable.
Now the chimney is inside a room addition
The satellite dish & antenna both remain attached in the same position as before, but I have to determine a new route for these cables.
I was thinking about running down the antenna mast and along the flashing on the chimney.
But my problem is how to secure it the remaining 12' or so until it reaches the guttering.
I don't want to nail anything to the new roof section.
Is there any type of wire clip that can be used to just push on to the shingle without nailing?
They make Christmas light string holders that clip on like that. I've used them on the edge of my roof to hold the light strings in place so I would think they would hold a cable.
Convert DirecTV single LNB setup for Dish Network
Help with a 500+
