Secret Menu | SatelliteGuys.US
Secret Menu
jrcorado
30
Maryland USA
Hello
I need help accessing the secret menu on an old Sony SD receiver. I need to put the receiver in stacked mode. The receiver's access card is inserted in the rear of the receiver. Please help.
Okay, I'm back
I tried a google search and found no information.
The receivers are Sony SAT-B50.
The antenna is a round single dish with a stacked LNB.
There are 3 receivers that were installed 7 years ago that are only detecting odd transponders.
there 2 receivers that work fine, same make and model.
Please only reply if you want to help
He's need a "SECRET" menu - not the lamer manual.
I'll try to setup same IRD and check if I recall correctly the commands.
Just for my curiosity - what exactly model of stacked LNBF your round dish have ?
NBA TV?
HD Extra Pack
