Searchkeys words. | SatelliteGuys.US
Searchkeys words.
Cincyray
180
Reading Pa
Hey all is there a list of searchkey words that can switch things after the ce is downloaded. I know if i wantmyvod but are there any others thanks.
that code has been out of use for many months. there is only one right now that allows you to change the order of you 'my playlist'.
I think it is still there, haven't tried it in a long time. that code is 'iamaedgecutter' as a keyword search, at the no results screen physically press menu and info on the boz at the same time.
Like I said, it doesn't do much and Im not sure if it is still there.
What's the difference with these two? I think I did the skip one and love it.
Slip, You see the programming FF ahead :30 secs.
Skip, the programming skips ahead :30 sec's., you don't see the programming.
Some like one way, other like the other way.
Personal preference.
Jimbo
HR20 -100 & -700 (HD-DVR) CE Release 2/1 & 2/2 ver: 0x1F8
R15 (ALL) CE Release 2/8 & 2/9 CANCELLED
