Searching for Signal problem | SatelliteGuys.US
JustinC83
26
Ok, I have a reciever that keeps searching for satellite. But when i do a reset from the menu, it wont search anymore and i will get programming. But then after alittle while it will search for signal again.
Now i hooked the reciever up in another room that has a line run to it and it works with no problem
im wondering if i should go trace the wire and see if maybe i might have to change a barrel (as i installed this reciever after my intial installation) Because he put all new barrels (the ones that are blue inside) on
or maybe it could be a connector has they are twist on connectors
saunds like a need for a new line.
hi
start from the swith, out side to the inside of your house, fallow that line and look for kinks:D or just run a new line from out side and if works fine thats it, you need a new line ............... good luck:cool:
making payment ahead of autopay
101/95 Dish pointing to 72.5
