Searching For Signal only on Local HD | SatelliteGuys.US
JustinC83
26
i get a message searching for signal but its only on my local HD channels, when i change the channel to the SD version of the same channel i dont get the message and all my other HD channels have signal
And it is for all my Local Ones, ABC,CBS, FOX, NBC,CW
really stumped here
but just another thing, there is a severe thunderstorm warning for some part of my state (nothing in my area its still sunny) could that maybe effect it?
but the only thing that makes me doubt it is no other channel is searching for satellite
Have you ever had your locals in HD yet ?
If not you may want to call D* and make sure that they have them turned on for you.
Even if you have previously, something weird may have happened and they were turned off ?
You say all your Sat HD channels come in, so that means you have your BBC's in place.
What kind of Signal Strength do you have on the 99s and 103 s ?
Most will be 0 or there abouts, you should have a few that are pretty high, (80+) at least one, thats where your getting your locals from ...
Check your signals and check back here before calling D* so we can try to help you out ahead of time.
Will MRV (whole home DVR) extend a contract?
Order Direct online or through local retailer?
