Where is the search button on the new cui
Searching by voice works pretty good too for the 50.0 voice remote.If you are using a 50 remote, Press Home twice...
The search button is on the remote.
where..............I am using the same remote that came with the HWS, & pushing the same button that I used to push for search, but I don't get the same results.
The format button works the same, but not the search
As JSheridan mentioned, it is working fine here as well. Now, look on the back of the remote at tell us which remote it is.where..............I am using the same remote that came with the HWS, & pushing the same button that I used to push for search, but I don't get the same results.
no I have not done a power cord reboot. It is a hassle to reach & unplug..........plus now I have a broken heel, which makes moving around even more difficult
yes, I did find the search button
maybe it was me that was screwed up..........I could have sworn that I always pushed the # for search
Limited time offer
