Scrolling bar on Panasonic Viera. | SatelliteGuys.US
outerub
100
Michigan.
TH-46PZ80U Panasonic Viera 1080p panel.
Translucent horizontal bar, scrolling from top to bottom, at all times when on SD channel, never on HD channel.
Motorola HD cable box.
Any ideas ?
Thanks.
UB. :)
Scrolling bar from top to bottom is generally a electrical hum bar. See if you see it while viewing a DVD. If not have the cable company come out and check thier groung. You also see them if you have high hat lights with a dimming switch.
Slightly confused on 4:3/16:9
NetFlix WatchNow using PlayOn and the Playstation 3
