Screens | SatelliteGuys.US
Screens
evilfud
25
Ok im looking at the Panasonic PT-AE900 for my Home Theatre i want to use it for HDTV,DVD,PC use,prolly Xbox 360. im thinking i want the projector about 12-13 feet back and would like a 100 inch diagonal fixed screen. I will have a controlled light room so do you guys have any reccomendations for a screen? i am looking to do the screen as cheap as possible without sacrificing quality.DIY or fixxed low priced screen mfg.
Thanks,
Chris
Right now I am using mellamine ( not sure if that is the spelling) a 4'x8' sheet in my Ht room for my X1 it works good. I got it at my local building supply place (Sutherlands) for less than a sheet of 3/8" plywood. I have another sheet I am going to paint to experiment with...I think Sams has screens now not sure on price though... I sent you a PM with more info...
Thanks tons of Screen info there. im now going throught it all to either help or hinder my choices in what to do heh,
Thanks,
Chris
Seanb61 .thats way more than i want to spend unless i really have to
digital optic splitter
Wireless TV Transmitter
