Science channel | SatelliteGuys.US
Science channel
sourdough
43
Alaska
Does anyone else in AT200 not see 193 (Science)? I used to receive it several months ago. TheList as well as Dish's site shows it on AT200.
Also according to TheList HD feeds for AK/HI are on 119 TP 03 and 05. Only the SD version is on 110 (which I can't get). Fox Business is similar and it works, I just ONLY see an HD version of it.
On the 119 list it appears that some of the mapdowns are marked as 'Not Available' I am wondering if that is the cause, however the affected mapdowns appear to be for the HI spotbeam.
I have a HWS, the channel disappeared before I upgraded from the 922 though.
Which sats does your system actually receive? To get all hd where I am you need 61.5 AND 72, or 110, 119 AND 129. The classic 110, 119 with 61.5 misses a lot these days. Winding what you have. ?.
The HD Science channel is on satellites 129 and 72.7. It is not available in the HD AT200 AK/HI package.
I have 119 and 129, no 110 (it's behind a mountain). I see that the SD version is on 110, but I also see HD versions on both 129 (in a conus TP) and on 119 TP 03 and 05. Why is it uplinked to 119 but not available?
Can you cut a hole in that mountain? :) I am faced with a similar situation with 129. However there is no mountain but a wall which blocks the LOS.
Fortunately I am not losing all that much by not having 110. I just have to hope dish never decides to move the bulk of programming over there...
Could your next DVR have more than three tuners please?
Used EHD to transfer programs now what?
