Saving recordings on external USB drive | SatelliteGuys.US
camo
898
331
Nebraska
Today my direct system is being installed. I want to get a 1T external USB HD for additional storage. My question; If you use a external HD and and the receiver fails, do you loose all the recordings on the external? I read some where that the receiver marries to the HD. I hope this is not true. I went through two receivers with dish over 3 years and was always able to keep my recordings.
Thanks anyone
Thanks anyone
Unfortunately the recordings will stay on the hd but you won't be able to access them. The way Directv set it up, the hd is tied to the dvr. You can't move the hd from one dvr to another.
Thanks anyone
USB drives won't work at all.
MRV works, then quits after a couple of days
New HD Box Freezing
