Save a DVR recording to Flash Drive or Hard Drive | SatelliteGuys.US
stellar832000
171
San Antonio
Hi guys I am in need of some help, my friend was recently on a local news broadcast and I recorded it to my HR24-100 is there any way I can save this show to a flash drive or even my computer? thanks in advance!!
If you have a DVD recorder, you could hook up the HR-24 to that (or hook up your HR-24 directly to a computer using a video capture device) with the RCA jacks (Red, White & Yellow), then record and burn it to DVD. Then you could rip it into your computer. Then you can put it on a flash drive or upload it to YouTube.
if you have video capture & recording capabilities on your PC you should be able to connect and capture directly to the PC in the file type / compression of choice..
Slimline Dish Aiming Problem
