Savannah Locals in Albany..possible? | SatelliteGuys.US
The Great One
9
I just want to know if I'm able to get Savannah locals in Albany. So if I "move" to Savannah would I be in the same spotbeam and able to get those locals. Since E* has taken Atlanta HD locals from south GA I think Savannah is the next best thing since they have all 4 networks in HD unlike when Albany goes live since Albany will only have 3 of the 4.
Savannah and Charleston are on SB44 on 129W on transponders 9 and 11. See what signal strength you get on 129 for those transponders. Go Menu 6 1 1, change the sat to 129W, and then change the transponder to the number desired.
SB44 map: http://www.satelliteguys.us/thelist/database/Subscription/images/CIEL2_SB44.jpg
You're on the edge but probably will get a decent signal strength.
You're also in SB50: http://www.satelliteguys.us/thelist/database/Subscription/images/CIEL2_SB50.jpg
SB50 currently carries New Orleans on T10.
You may be in the fringe for SB43, carrting Atlanta on T4 and three of the Monty locals on T8: http://www.satelliteguys.us/thelist/database/Subscription/images/CIEL2_SB43.jpg
If you have a 61.5 dish see if you have any signal strengths on that sat for the lower transponder numbers (one through fifteen).
I'm definitely within the green circle on SB44. I still get ATL locals just not in HD because they were moved. I'm just looking for the best option of moving. I would like to stay in GA so that the NFL and MLB games would still be Atlanta teams not Jacksonville or such.
922 Question
Smart Card Question
