SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/06/2007 | SatelliteGuys.US
digiblur
14,190
4
Louisiana
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/06/2007 - 11 changes
Uplink Comparison Range: 10/02/2007 12:23A - 10/02/2007 01:08P -
285 - SHO-E [MPEG2 HD] - EchoStar8 110W TP 13 ConUS beam changed to Not Available
288 - SHO-E [MPEG2 SD] - EchoStar7 119W TP 06 ConUS beam changed to Not Available
289 - SHO-W [MPEG2 SD] - EchoStar7 119W TP 08 ConUS beam changed to Not Available
290 - SHOTO [MPEG2 SD] - EchoStar7 119W TP 19 ConUS beam changed to Not Available
291 - SHOCS [MPEG2 SD] - EchoStar8 110W TP 21 ConUS beam changed to Not Available
292 - SHOEX [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed to Not Available
293 - SBYND [MPEG2 SD] - EchoStar8 110W TP 11 ConUS beam changed to Not Available
294 - TMC-E [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Not Available
295 - TMCXE [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Not Available
296 - SUND [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Not Available
297 - FLIX [MPEG2 SD] - EchoStar7 119W TP 17 ConUS beam changed to Not Available
Channels in the system: 4476
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/06/2007 - 62 changes
Uplink Comparison Range: 10/03/2007 09:36A - 10/03/2007 12:24P -
281 - ESPNU EchoStar7 119W TP 04 ConUS beam MPEG2 SD changed to VERIA - EchoStar8 110W TP 03 ConUS beam
282 - VS. [MPEG2 SD] - EchoStar8 110W TP 01 ConUS beam changed to Not Available
283 - FSC [MPEG2 SD] - EchoStar8 110W TP 11 ConUS beam changed to Not Available
290 - SHOTO EchoStar7 119W TP 19 ConUS beam changed to HBO-E - EchoStar7 119W TP 02 ConUS beam (NA)
291 - SHOCS EchoStar8 110W TP 21 ConUS beam changed to HBO2E - EchoStar7 119W TP 06 ConUS beam (NA)
292 - SHOEX EchoStar7 119W TP 16 ConUS beam changed to HBOSG - EchoStar7 119W TP 06 ConUS beam (NA)
293 - SBYND EchoStar8 110W TP 11 ConUS beam changed to HBO-W - EchoStar7 119W TP 19 ConUS beam (NA)
294 - TMC-E EchoStar7 119W TP 10 ConUS beam changed to HBO2W - EchoStar7 119W TP 13 ConUS beam (NA)
295 - TMCXE EchoStar7 119W TP 10 ConUS beam changed to HBOFM - EchoStar7 119W TP 08 ConUS beam (NA)
296 - SUND EchoStar7 119W TP 12 ConUS beam changed to HBOCY - EchoStar8 110W TP 11 ConUS beam (NA)
297 - FLIX EchoStar7 119W TP 17 ConUS beam changed to HBOLT - EchoStar8 110W TP 21 ConUS beam (NA)
385 - FOXNE renamed to CSNNE (NA)
408 - TEMP (NA) removed from EchoStar8 110W TP 19 ConUS beam
435 - FOXNE renamed to CSNNE (A)
574 - FPCHN EchoStar1 148W TP 25 ConUS beam MPEG2 SD moved to EchoStar1 148W TP 27 ConUS beam
574 - FPCHN EchoStar3 61.5W TP 12 ConUS beam MPEG2 SD moved to EchoStar3 61.5W TP 16 ConUS beam
575 - FPCHN EchoStar1 148W TP 25 ConUS beam MPEG2 SD moved to EchoStar1 148W TP 27 ConUS beam
575 - FPCHN EchoStar3 61.5W TP 12 ConUS beam MPEG2 SD moved to EchoStar3 61.5W TP 16 ConUS beam
753 - XTV [MPEG2 SD] added to Anik F3 118.7W TP 19 ConUS beam (Not Available)
754 - ZTV [MPEG2 SD] added to Anik F3 118.7W TP 25 ConUS beam (Not Available)
812 - MH1 [MPEG2 SD] - Anik F3 118.7W TP 24 ConUS beam changed to Available
858 - TFMLA [MPEG2 SD] - EchoStar8 110W TP 19 ConUS beam changed to Available
5748 - TWCV2 (A) removed from EchoStar1 148W TP 23 ConUS beam
7698 - WHMM renamed to KGLA (A)
8283 - WTGL renamed to WHLV (A)
8284 - WLCB renamed to WTGL (A)
9543 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9543 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9544 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9544 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9545 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9545 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9546 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9546 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9547 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9547 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9548 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9548 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9549 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9549 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9550 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9550 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9551 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9551 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9552 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9552 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9553 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9553 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9554 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9554 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9555 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9555 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9556 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9556 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9557 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9557 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9558 - NHLHD [MPEG4 HD] - EchoStar5 129W TP 08 ConUS beam changed to Available
9558 - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed to Available
9575 - VERIA [MPEG2 SD] - EchoStar8 110W TP 03 ConUS beam changed to Available
9646 - ATT [MPEG4 HD] added to EchoStar5 129W TP 06 ConUS beam (Not Available)
9901 - D1000 renamed to D129 (A)
19026 - WTHR3 (NA) removed from EchoStar8 110W TP 14 ConUS beam
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/06/2007 - 8 changes
Uplink Comparison Range: 10/03/2007 12:59P - 10/03/2007 06:47P -
290 - HBO-E [MPEG2 SD] - EchoStar7 119W TP 02 ConUS beam changed to Available
291 - HBO2E [MPEG2 SD] - EchoStar7 119W TP 06 ConUS beam changed to Available
292 - HBOSG [MPEG2 SD] - EchoStar7 119W TP 06 ConUS beam changed to Available
293 - HBO-W [MPEG2 SD] - EchoStar7 119W TP 19 ConUS beam changed to Available
294 - HBO2W [MPEG2 SD] - EchoStar7 119W TP 13 ConUS beam changed to Available
295 - HBOFM [MPEG2 SD] - EchoStar7 119W TP 08 ConUS beam changed to Available
296 - HBOCY [MPEG2 SD] - EchoStar8 110W TP 11 ConUS beam changed to Available
297 - HBOLT [MPEG2 SD] - EchoStar8 110W TP 21 ConUS beam changed to Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/06/2007 - 13 changes
Uplink Comparison Range: 10/03/2007 11:23P - 10/04/2007 08:07A -
5992 - XKNXV [MPEG2 SD] - EchoStar7 119W TP 05 Arizona beam changed to Available
5993 - XKPHO [MPEG2 SD] - EchoStar7 119W TP 05 Arizona beam changed to Available
5994 - XKPNX [MPEG2 SD] - EchoStar7 119W TP 05 Arizona beam changed to Available
5995 - XKSAZ [MPEG2 SD] - EchoStar7 119W TP 05 Arizona beam changed to Available
5996 - XKTVK [MPEG2 SD] - EchoStar7 119W TP 05 Arizona beam changed to Available
5997 - XKTVW [MPEG2 SD] - EchoStar7 119W TP 05 Arizona beam changed to Available
5998 - XKTAZ [MPEG2 SD] - EchoStar7 119W TP 05 Arizona beam changed to Available
5999 - XKFPH [MPEG2 SD] - EchoStar7 119W TP 05 Arizona beam changed to Available
8324 - KASW moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8325 - KUTP moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8326 - KAET moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8331 - KAZT moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
8338 - KMOH moved from EchoStar7 119W TP 05 Arizona beam to EchoStar10 110W TP 20 Spotbeam 35(AZ) (A)
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/06/2007 - 4 changes
Uplink Comparison Range: 10/04/2007 08:07A - 10/04/2007 10:18P -
285 - SHO-E EchoStar8 110W TP 13 ConUS beam MPEG2 HD changed to HBO - EchoStar8 110W TP 13 ConUS beam
542 - HDPPV [MPEG4 HD] - EchoStar5 129W TP 06 ConUS beam changed to Not Available
542 - HDPPV [MPEG4 HD] - EchoStar3 61.5W TP 22 ConUS beam changed to Not Available
Transponder Changes:
EchoStar10 110W TP 18 Spotbeam 35 changed FEC from 5/6 to 2/3
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 10/06/2007 - 2 changes
Uplink Comparison Range: 10/05/2007 01:26P - 10/05/2007 04:30P -
542 - HDPPV EchoStar5 129W TP 06 ConUS beam MPEG4 HD changed to TBS - EchoStar5 129W TP 06 ConUS beam
542 - HDPPV EchoStar3 61.5W TP 22 ConUS beam MPEG4 HD changed to TBS - EchoStar3 61.5W TP 22 ConUS beam
converting from dish to directv question
TBS HD is Live
