SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/02/2008 | SatelliteGuys.US
digiblur
14,190
4
Louisiana
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/02/2008 - 51 changes
Uplink Comparison Range: 01/29/2008 07:58A - 01/30/2008 01:54P -
102 - PREVW [MPEG2 SD] - EchoStar8 110W TP 02 ConUS beam changed to Available
127 - OXYGN - EchoStar7 119W TP 17 ConUS beam changed flags from 0101027C00FCFF to 0101027C00FDFF
130 - AMC - EchoStar7 119W TP 08 ConUS beam changed flags from 0101028B00FCFF to 0101028B00FDFF
131 - IFC - EchoStar7 119W TP 06 ConUS beam changed flags from 0101026D00FCFF to 0101026D00FDFF
146 - ESP2A moved from EchoStar8 110W TP 24 ConUS beam to EchoStar7 119W TP 10 ConUS beam (A)
158 - FUSE - EchoStar7 119W TP 02 ConUS beam changed flags from 0101026500FCFF to 0101026500FDFF
185 - HLMRK - EchoStar8 110W TP 11 ConUS beam changed flags from 0101028000FCFF to 0101028000FDFF
192 - DTIME renamed to ID (A)
280 - FREE (A) removed from EchoStar8 110W TP 02 ConUS beam
281 - ANIML (A) removed from EchoStar7 119W TP 02 ConUS beam
282 - DHLTH (A) removed from EchoStar7 119W TP 17 ConUS beam
468 - ORDER [MPEG2 HD] added to EchoStar8 110W TP 19 ConUS beam (Not Available)
473 - XGAM1 (A) removed from EchoStar7 119W TP 18 ConUS beam
474 - XGAM2 (A) removed from EchoStar7 119W TP 12 ConUS beam
475 - XGAM3 (A) removed from EchoStar8 110W TP 16 ConUS beam
476 - XGAM4 (A) removed from EchoStar8 110W TP 16 ConUS beam
477 - XGAM5 (A) removed from EchoStar7 119W TP 18 ConUS beam
478 - XGAM6 (A) removed from EchoStar7 119W TP 10 ConUS beam
657 - ONGME (A) removed from EchoStar1 148W TP 07 ConUS beam
657 - ONGME (A) removed from EchoStar3 61.5W TP 14 ConUS beam
658 - BTN (A) removed from EchoStar1 148W TP 07 ConUS beam
658 - BTN (A) removed from EchoStar3 61.5W TP 14 ConUS beam
759 - ARTMV moved from EchoStar9 121W TP 29 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
760 - LBC moved from EchoStar9 121W TP 29 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
761 - ALJAZ moved from EchoStar9 121W TP 21 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
762 - ESC-1 moved from EchoStar9 121W TP 22 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
780 - ZIKR (A) removed from EchoStar9 121W TP 29 ConUS beam
781 - ARTMU (A) removed from EchoStar9 121W TP 29 ConUS beam
812 - MH1 - Anik F3 118.7W TP 24 ConUS beam changed flags from 010100BC00FCFF to 010100BC00FDFF
815 - RCORD (A) removed from EchoStar9 121W TP 13 ConUS beam
817 - SPT (A) removed from EchoStar9 121W TP 13 ConUS beam
850 - HISTE [MPEG2 SD] - EchoStar8 110W TP 05 ConUS beam changed to Available
5701 - ARTMV [MPEG2 SD] added to EchoStar9 121W TP 29 ConUS beam (Available)
5702 - LBC [MPEG2 SD] added to EchoStar9 121W TP 29 ConUS beam (Available)
5708 - RCORD (A) removed from EchoStar9 121W TP 15 ConUS beam
5709 - SPT (A) removed from EchoStar9 121W TP 18 ConUS beam
5715 - ALJAZ [MPEG2 SD] added to EchoStar9 121W TP 21 ConUS beam (Available)
5717 - ESC-1 [MPEG2 SD] added to EchoStar9 121W TP 22 ConUS beam (Available)
5730 - ONGME (A) removed from EchoStar1 148W TP 03 ConUS beam
5730 - ONGME (A) removed from EchoStar3 61.5W TP 10 ConUS beam
5739 - BTN (A) removed from EchoStar1 148W TP 29 ConUS beam
5739 - BTN (A) removed from EchoStar3 61.5W TP 31 ConUS beam
7189(7) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7197(29) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7910(6) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
7916(25) - INFO [MPEG2 SD] added to AMC-15 105W TP 02 ConUS beam (Available)
9130(67) - WNGS [MPEG2 SD] - EchoStar10 110W TP 29 Spotbeam 09 changed to Available
9464 - ORDER [MPEG2 HD] added to EchoStar8 110W TP 19 ConUS beam (Not Available)
9548 - NHLHD moved from EchoStar5 129W TP 27 ConUS beam to EchoStar5 129W TP 08 ConUS beam (A)
19001 - ORDH (NA) removed from EchoStar8 110W TP 15 ConUS beam
19123 - DISAV - EchoStar8 110W TP 02 ConUS beam changed flags from 010107E600FDFF to 010107E600FCFF
Channels in the system: 4554
(A) = Available to subscribers
(NA) = Not Available
Discussion Thread Here
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/02/2008 - 29 changes
Uplink Comparison Range: 01/30/2008 01:54P - 01/31/2008 06:28A -
5300 - ESPN [MPEG4 HD] added to EchoStar8 110W TP 07 ConUS beam (Available)
5301 - ESPN2 [MPEG4 HD] added to EchoStar5 129W TP 30 ConUS beam (Available)
5301 - ESPN2 [MPEG4 HD] added to EchoStar3 61.5W TP 02 ConUS beam (Available)
5310 - HGTV [MPEG4 HD] added to EchoStar5 129W TP 30 ConUS beam (Available)
5310 - HGTV [MPEG4 HD] added to EchoStar3 61.5W TP 02 ConUS beam (Available)
5311 - FOOD [MPEG4 HD] added to EchoStar5 129W TP 30 ConUS beam (Available)
5311 - FOOD [MPEG4 HD] added to EchoStar3 61.5W TP 02 ConUS beam (Available)
5312 - A&E [MPEG4 HD] added to EchoStar5 129W TP 27 ConUS beam (Available)
5312 - A&E [MPEG4 HD] added to EchoStar3 61.5W TP 22 ConUS beam (Available)
5313 - HIST [MPEG4 HD] added to EchoStar5 129W TP 31 ConUS beam (Available)
5313 - HIST [MPEG4 HD] added to EchoStar3 61.5W TP 22 ConUS beam (Available)
5320 - MHD [MPEG4 HD] added to EchoStar5 129W TP 19 ConUS beam (Available)
5320 - MHD [MPEG4 HD] added to Echostar12 61.5W TP 19 ConUS beam (Available)
5330 - DISC [MPEG4 HD] added to EchoStar5 129W TP 19 ConUS beam (Available)
5330 - DISC [MPEG4 HD] added to Echostar12 61.5W TP 19 ConUS beam (Available)
5331 - TLC [MPEG4 HD] added to EchoStar5 129W TP 19 ConUS beam (Available)
5331 - TLC [MPEG4 HD] added to Echostar12 61.5W TP 19 ConUS beam (Available)
5332 - ANIML [MPEG4 HD] added to EchoStar5 129W TP 19 ConUS beam (Available)
5332 - ANIML [MPEG4 HD] added to Echostar12 61.5W TP 19 ConUS beam (Available)
5333 - HDTHR [MPEG4 HD] added to EchoStar8 110W TP 13 ConUS beam (Available)
5334 - NTGEO [MPEG4 HD] added to EchoStar5 129W TP 30 ConUS beam (Available)
5334 - NTGEO [MPEG4 HD] added to EchoStar3 61.5W TP 22 ConUS beam (Available)
5350 - HDNET [MPEG4 HD] added to EchoStar8 110W TP 07 ConUS beam (Available)
5351 - HDNMV [MPEG4 HD] added to EchoStar8 110W TP 07 ConUS beam (Available)
5352 - TBS [MPEG4 HD] added to EchoStar5 129W TP 06 ConUS beam (Available)
5352 - TBS [MPEG4 HD] added to EchoStar3 61.5W TP 22 ConUS beam (Available)
5353 - TNT [MPEG4 HD] added to EchoStar8 110W TP 07 ConUS beam (Available)
5354 - UNIHD [MPEG4 HD] added to EchoStar5 129W TP 31 ConUS beam (Available)
5354 - UNIHD [MPEG4 HD] added to EchoStar3 61.5W TP 22 ConUS beam (Available)
Channels in the system: 4583
I was wondering why they didn't flag them as MPEG2 ViP before.
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/02/2008 - 7 changes
Uplink Comparison Range: 01/31/2008 06:28A - 01/31/2008 03:34P -
5300 - ESPN EchoStar8 110W TP 07 ConUS beam changed from MPEG4 HD to MPEG2 ViP (A)
5333 - HDTHR EchoStar8 110W TP 13 ConUS beam changed from MPEG4 HD to MPEG2 ViP (A)
5350 - HDNET EchoStar8 110W TP 07 ConUS beam changed from MPEG4 HD to MPEG2 ViP (A)
5351 - HDNMV EchoStar8 110W TP 07 ConUS beam changed from MPEG4 HD to MPEG2 ViP (A)
5353 - TNT EchoStar8 110W TP 07 ConUS beam changed from MPEG4 HD to MPEG2 ViP (A)
7566 - KREX moved from EchoStar8 110W TP 22 ConUS beam to EchoStar10 110W TP 26 Spotbeam 34(UT) (A)
7568 - KFQX moved from EchoStar8 110W TP 22 ConUS beam to EchoStar10 110W TP 26 Spotbeam 34(UT) (A)
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 02/09/2008 - 1 change
Uplink Comparison Range: 02/04/2008 12:47A - 02/04/2008 03:28P -
8919 - KUQI EchoStar10 110W TP 27 Spotbeam 17 mapdown of 38 added (A)
NHL Center Ice
Help... offers for current customers to upgrade my 811
