SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 01/26/2008 | SatelliteGuys.US
digiblur
14,190
4
Louisiana
Uplink Discussion Thread - Click Here
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 01/26/2008 - 42 changes
Uplink Comparison Range: 01/21/2008 08:56P - 01/23/2008 12:03P -
102 - PREVW [MPEG2 SD] added to EchoStar8 110W TP 02 ConUS beam (Not Available)
473 - XGAM1 [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed to Available
474 - XGAM2 [MPEG2 SD] - EchoStar7 119W TP 12 ConUS beam changed to Available
475 - XGAM3 [MPEG2 SD] - EchoStar8 110W TP 16 ConUS beam changed to Available
476 - XGAM4 [MPEG2 SD] - EchoStar8 110W TP 16 ConUS beam changed to Available
477 - XGAM5 [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed to Available
478 - XGAM6 [MPEG2 SD] - EchoStar7 119W TP 10 ConUS beam changed to Available
717 - LEOWD moved from EchoStar1 148W TP 09 ConUS beam to EchoStar1 148W TP 07 ConUS beam (A)
717 - LEOWD moved from EchoStar3 61.5W TP 08 ConUS beam to EchoStar3 61.5W TP 14 ConUS beam (A)
787 - ZEETV moved from EchoStar9 121W TP 29 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
788 - TVASA moved from EchoStar9 121W TP 15 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
789 - SET moved from EchoStar9 121W TP 15 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
790 - ZCINE moved from EchoStar9 121W TP 29 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
791 - B4U moved from EchoStar9 121W TP 29 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
794 - AAJTK moved from EchoStar9 121W TP 16 ConUS beam to EchoStar9 121W TP 13 ConUS beam (A)
810 - ASIFM (A) removed from EchoStar9 121W TP 22 ConUS beam
902 - GEONW [MPEG2 SD] added to Anik F3 118.7W TP 07 ConUS beam (Not Available)
902 - GEONW [MPEG2 SD] added to EchoStar3 61.5W TP 32 ConUS beam (Not Available)
903 - AAGTV [MPEG2 SD] added to Anik F3 118.7W TP 07 ConUS beam (Not Available)
903 - AAGTV [MPEG2 SD] added to EchoStar3 61.5W TP 32 ConUS beam (Not Available)
5703 - ZCINE [MPEG2 SD] added to EchoStar9 121W TP 29 ConUS beam (Available)
5706 - SET [MPEG2 SD] added to EchoStar9 121W TP 15 ConUS beam (Available)
5707 - AAJTK [MPEG2 SD] added to EchoStar9 121W TP 16 ConUS beam (Available)
5712 - B4U [MPEG2 SD] added to EchoStar9 121W TP 29 ConUS beam (Available)
5714 - ZEETV [MPEG2 SD] added to EchoStar9 121W TP 29 ConUS beam (Available)
5723 - TVASA [MPEG2 SD] added to EchoStar9 121W TP 15 ConUS beam (Available)
5960 - XWJET [MPEG2 SD] added to EchoStar9 121W TP 30 ConUS beam (Available)
5961 - XWSEE [MPEG2 SD] added to EchoStar9 121W TP 30 ConUS beam (Available)
5965 - XWAOW [MPEG2 SD] added to EchoStar9 121W TP 01 ConUS beam (Available)
5966 - XWSAW [MPEG2 SD] added to EchoStar9 121W TP 01 ConUS beam (Available)
5969 - XKSWO [MPEG2 SD] added to EchoStar9 121W TP 09 ConUS beam (Available)
5970 - XKAUZ [MPEG2 SD] added to EchoStar9 121W TP 09 ConUS beam (Available)
5974 - XWLNE [MPEG2 SD] added to EchoStar9 121W TP 14 ConUS beam (Available)
5975 - XWPRI [MPEG2 SD] added to EchoStar9 121W TP 14 ConUS beam (Available)
7041 - WJET moved from EchoStar9 121W TP 30 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7042 - WSEE moved from EchoStar9 121W TP 30 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7210 - WAOW moved from EchoStar9 121W TP 01 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7211 - WSAW moved from EchoStar9 121W TP 01 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7860 - KSWO moved from EchoStar9 121W TP 09 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
7861 - KAUZ moved from EchoStar9 121W TP 09 ConUS beam to EchoStar9 121W TP 14 ConUS beam (A)
8919 - KUQI [MPEG2 SD] added to EchoStar10 110W TP 27 Spotbeam 17 (Not Available)
9465 - HDEV1 renamed to MAVHD (A)
Channels in the system: 4568
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US DishNetwork Uplink Activity Report - Week Ending 01/26/2008 - 16 changes
Uplink Comparison Range: 01/23/2008 02:03P - 01/24/2008 08:19A -
403 - NHLN moved from EchoStar5 129W TP 06 ConUS beam to EchoStar5 129W TP 30 ConUS beam (A)
403 - NHLN moved from Echostar12 61.5W TP 09 ConUS beam to EchoStar3 61.5W TP 02 ConUS beam (A)
559 - NHLN moved from EchoStar5 129W TP 06 ConUS beam to EchoStar5 129W TP 30 ConUS beam (A)
559 - NHLN moved from Echostar12 61.5W TP 09 ConUS beam to EchoStar3 61.5W TP 02 ConUS beam (A)
7566 - KREX moved from EchoStar10 110W TP 26 Spotbeam 34(UT) to EchoStar8 110W TP 22 ConUS beam (A)
7568 - KFQX moved from EchoStar10 110W TP 26 Spotbeam 34(UT) to EchoStar8 110W TP 22 ConUS beam (A)
9427 - UNIHD moved from EchoStar5 129W TP 27 ConUS beam to EchoStar5 129W TP 31 ConUS beam (A)
9473 - TRESR moved from EchoStar5 129W TP 11 ConUS beam to EchoStar5 129W TP 23 ConUS beam (A)
9473 - TRESR moved from Echostar12 61.5W TP 09 ConUS beam to Echostar12 61.5W TP 13 ConUS beam (A)
9475 - WORLD moved from EchoStar5 129W TP 11 ConUS beam to EchoStar5 129W TP 22 ConUS beam (A)
9475 - WORLD moved from Echostar12 61.5W TP 09 ConUS beam to Echostar12 61.5W TP 24 ConUS beam (A)
9477 - WSPOR moved from EchoStar5 129W TP 11 ConUS beam to EchoStar5 129W TP 19 ConUS beam (A)
9477 - WSPOR moved from Echostar12 61.5W TP 09 ConUS beam to Echostar12 61.5W TP 19 ConUS beam (A)
9491 - HIST moved from EchoStar5 129W TP 27 ConUS beam to EchoStar5 129W TP 31 ConUS beam (A)
9500 - BIG10 moved from Echostar12 61.5W TP 09 ConUS beam to EchoStar3 61.5W TP 30 ConUS beam (A)
Transponder Changes:
Echostar12 61.5W TP 09 ConUS beam 8PSK removed from tables
722 placed on its side okay??
Mlb Ei?
