SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 09/08/2007 | SatelliteGuys.US
digiblur
14,190
4
Louisiana
SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 09/08/2007 - 3 changes
Uplink Comparison Range: 08/31/2007 08:41A - 09/04/2007 08:12A -
386 - RUGBY [MPEG2 SD] added to Nimiq1/4 91W TP 28 Canada/US beam (Available)
640 - DHSM renamed to DMTR (A)
642 - DHSM* renamed to DMTR* (A)
Channels in the system: 813
(A) = Available to subscribers
(NA) = Not Available
SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 09/08/2007 - 2 changes
Uplink Comparison Range: 09/04/2007 08:12A - 09/05/2007 08:21A -
567 - RETRO* [MPEG2 SD] added to Nimiq1/4 91W TP 05 Canada/US beam (Available)
582 - LOUD* [MPEG2 SD] added to Nimiq1/4 91W TP 05 Canada/US beam (Available)
Channels in the system: 815
SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 09/08/2007 - 27 changes
Uplink Comparison Range: 09/05/2007 08:21A - 09/06/2007 05:49P -
450 - NFLI [OpenTV] - Nimiq1/4 91W TP 22 Canada/US beam changed to Available
451 - NFL1 [MPEG2 SD] - Nimiq1/4 91W TP 25 Canada/US beam changed to Available
452 - NFL2 [MPEG2 SD] - Nimiq1/4 91W TP 15 Canada/US beam changed to Available
453 - NFL3 [MPEG2 SD] - Nimiq1/4 91W TP 08 Canada/US beam changed to Available
454 - NFL4 [MPEG2 SD] - Nimiq1/4 91W TP 06 Canada/US beam changed to Available
455 - NFL5 [MPEG2 SD] - Nimiq1/4 91W TP 21 Canada/US beam changed to Available
456 - NFL6 [MPEG2 SD] - Nimiq1/4 91W TP 10 Canada/US beam changed to Available
457 - NFL7 [MPEG2 SD] - Nimiq1/4 91W TP 29 Canada/US beam changed to Available
458 - NFL8 [MPEG2 SD] - Nimiq1/4 91W TP 30 Canada/US beam changed to Available
459 - NFL9 [MPEG2 SD] - Nimiq1/4 91W TP 13 Canada/US beam changed to Available
460 - NFL10 [MPEG2 SD] - Nimiq1/4 91W TP 04 Canada/US beam changed to Available
465 - NFLH1 [MPEG2 HD] - Nimiq2/3 82W TP 18 Canada/US beam changed to Available
466 - NFLH2 [MPEG2 HD] - Nimiq2/3 82W TP 18 Canada/US beam changed to Available
467 - NFLH3 [MPEG2 HD] - Nimiq2/3 82W TP 12 Canada/Non SE US beam changed to Available
468 - NFLH4 [MPEG2 HD] - Nimiq2/3 82W TP 12 Canada/Non SE US beam changed to Available
469 - NFLH5 Nimiq2/3 82W TP 30 Canada/US beam (0X89) changed to NFLH5 - Nimiq2/3 82W TP 12 Canada/Non SE US beam
470 - NFLH6 [(0X89)] added to Nimiq2/3 82W TP 18 Canada/US beam (Available)
870 - NFLH1* (NA) removed from Nimiq2/3 82W TP 18 Canada/US beam
871 - NFLH2* (NA) removed from Nimiq2/3 82W TP 18 Canada/US beam
872 - NFLH3* (NA) removed from Nimiq2/3 82W TP 12 Canada/Non SE US beam
873 - NFLH4* (NA) removed from Nimiq2/3 82W TP 12 Canada/Non SE US beam
874 - NFLH5* (A) removed from Nimiq2/3 82W TP 30 Canada/US beam
876 - CBSHE2 (A) removed from Nimiq2/3 82W TP 32 Canada/US beam
877 - CBSHW2 (A) removed from Nimiq2/3 82W TP 31 Canada/Non SE US beam
878 - FOXHE2 (A) removed from Nimiq2/3 82W TP 14 Canada/US beam
879 - FOXHW2 (A) removed from Nimiq2/3 82W TP 27 Canada/Non SE US beam
9888 - NSTI (A) removed from Nimiq1/4 91W TP 08 Canada/US beam
Channels in the system: 806
So Expressvu is up to the same trick as their HDPPV offerings - put 3 HD channels in MPEG2 on 1 transponder
Just gotta love 8 to 9 MB rates on MPEG2 HD - Compressvu HD Lite
They do it for the MLB HD games in the EI package too, to put it nicely they look nasty..
weird...these use to be on Nimiq2...unless they're still there too??
When you go to 567 or 582 it's just a message to tell to customers that Much More Retro and Much Loud has be remove from ExpressVu channels list.
Iceberg, looks as if the CH network has been rebranded as a knockoff of the American 'E!' network, and that the move was effective today, so odds are there will be some name changes coming down the pipe soon...
SatelliteGuys.US Bell ExpressVU Uplink Activity Report - Week Ending 09/08/2007 - 14 changes
Uplink Comparison Range: 09/06/2007 05:49P - 09/07/2007 08:37P -
207 - CH-M renamed to E!MTL (A)
218 - CH-H renamed to E!ONT (A)
255 - CH-VI renamed to E!BC (A)
896 - COMM [MPEG2 SD] added to Nimiq1/4 91W TP 13 Canada/US beam (Available)
8451 - NFL1H [(0X89)] - Nimiq1/4 91W TP 25 Canada/US beam changed to Available
8452 - NFL2H [(0X89)] - Nimiq1/4 91W TP 15 Canada/US beam changed to Available
8453 - NFL3H [(0X89)] - Nimiq1/4 91W TP 08 Canada/US beam changed to Available
8454 - NFL4H [(0X89)] - Nimiq1/4 91W TP 06 Canada/US beam changed to Available
8455 - NFL5H [(0X89)] - Nimiq1/4 91W TP 21 Canada/US beam changed to Available
8456 - NFL6H [(0X89)] - Nimiq1/4 91W TP 10 Canada/US beam changed to Available
8457 - NFL7H [(0X89)] - Nimiq1/4 91W TP 29 Canada/US beam changed to Available
8458 - NFL8H [(0X89)] - Nimiq1/4 91W TP 30 Canada/US beam changed to Available
8459 - NFL9H [(0X89)] - Nimiq1/4 91W TP 13 Canada/US beam changed to Available
8460 - NF10H [(0X89)] - Nimiq1/4 91W TP 04 Canada/US beam changed to Available
Channels in the system: 807
ExpressVU is showing HowardTV
expressvu tech portal
