SatelliteGuys Special Offer | SatelliteGuys.US
SatelliteAV
6,486
186
Roseville, CA
Blowout Pricing $ 325 any quantity
Lacuna Mark III Satellite Identification Meter
Suggested Retail $430
For more information visit LACUNA MARK 3 SAT IDENTIFICATION METER - SatelliteAV, LLC.
lacuna \luh-KYOO-nuh\, noun;
plural lacunae \luh-KYOO-nee\ or lacunas:
1. A blank space; a missing part; a gap.
Lacuna has listened to the thousands of professional satellite installers who own Lacuna products and made the best satellite meter even better! The New Lacuna Mark 3 meter will assist with making your satellite installs faster and more accurate, resulting in better income potential and less service calls!
New Features:
  • Extended Run time with a larger capacity battery
  • Operate the meter while charging
  • Powers up to last used satellite and transponder
  • LNBF test function
  • Six data groups to organize 120 satellites and thousands of transponder combinations
  • Easy navigation with new multi-button touch panel and streamlined menus
  • New 4 line LCD display features high and low signal level indicators with Quality (BER) reading
  • USB connection upgrade port for easy access and connection to a laptop (cable not included)
  • User adjustable Quality (BER) sensitivity settings
  • User adjustable auto-off timer
Standard Features:
  • Control 22KHz, DiSEqC, DP and Multi - switches
  • 120VAC wall charger
  • 12VDC accessory / cigarette lighter charger
  • Water resistant soft carrying case
  • Preloaded with the most current satellite and transponder lists
  • Easily upgrade to latest firmware and updated datasets
Easily update your meter with the latest satellite and transponder lists available at satmeter infosite - home
Identifies and peaks quality for the following standard applications:
  • Dish Network - All including DP Plus
  • DirecTV - All including AT-9
  • Starband
  • DirecWay
  • Free to Air
  • KA-Band
  • KU-Band
  • C-Band
  • Circular
  • Linear
  • Universal
  • Standard
  • Band Stacking
Absolutely the easiest meter to use!
I have one of these, and I finally got to use it to install my DirecTV dish a few weeks ago and it worked great. In fact my signal levels were as good if not better then someone whos a professional installing the dish.
If you check out my DirecTV diary I talk about this meter in there a bit.
I was VERY happy to have this meter and it made installing this difficult dish to install a breeze!
Thanks for the great offer for our members SatelliteAV.
Does Anyone Know of any 24/7 Analog Ku Channels ITC?
FTA installer Harrisburg PA
