Satellite Update (OTA-SSU) 2012.7.6 Firmware on back-up transponder for Testing | SatelliteGuys.US
  • Thread starter Thread starter SatelliteAV
  • Start date Start date
  • Replies Replies 0
  • Views Views 1K
SatelliteAV
6,486
186
Roseville, CA
GEOSATpro firmware 2012.7.6 OTA-SSU updating on satellite Galaxy 19, transponder frequency 12115. Do not change any other settings in the Manual Update Menu screen.
Warning: The 2012.7.6 update is a main system file and should not overwrite your settings and channel scans. You should back-up your current settings, set-up and firmware to a USB drive before performing the S/W Update via Satellite - Manual.
Back-up your current firmware to USB - Save to USB (ALLCODE) .abs
Save your user data to USB - Save to USB (userdb) .udf
Highlight S/W Update via Satellite - Manual, press OK.
On this release, please ignore the prompt that this is the same software as currently installed. This incorrect display will be corrected in this update.
MicroHD Firmware Release Notes:
Date: 7/06/2012
HDVS54012-1108249A0 2012-7-6
* DiSEqC 1.2: Fixed 22khz Bug in Motor/Switch Setting Menu affecting DiSEqC 1.2 "SAVE"
* Set Default Resolution 720p_60hz
* DVR Manual Record Duration - Fixed Bug occurring after 12pm
* Satellite OTA_SSU Update - Firmware Only (does not over-write Satellite/Transponder/Channel lists). Disregard the "Same Software" notice on the OTA-SSU.
The Case of the Stubbornly Silent Channel
microHD Quality Meter Linearity?
