satellite receiver c band k/u band zenith 2500 le parental control lock | SatelliteGuys.US
valmeida
2
new jersey
because i lost the remote on my uniden supra. I'm trying to set up a zenith 2500 Le that was my old receiver but i got the parental control lock on,i tried the receiver original code 2500 but no luck still lock on.it's there anybody that can tell me how to unlock the receiver thanks . Vitor :mad:
Zenith 2500le[ parent control lock
use the link and goto parental locks
/quote]
thank you but
I did that and i got a error message wrong password i guess i had a different password but was so long a go that i use it last time, i can't remember the old password , any way to over ride the old password?
I seem to remember that Zenith receivers are clones of Drake receivers. If so, I've read that on Drake receivers that you do:
[FONT=Times New Roman,Times]HELP-LOCK-0000
The HELP and LOCK are remote keys, not that you try to key in those words.
May not work on Zenith receivers, but if nothing else works, it's worth a try.
[/FONT]
Struggling with pointing
Sonicview Elite Slave to 922 or 922 Slave to Sonicview Elite
