satellite meter help | SatelliteGuys.US
meninpink
5
dallas
Is the Birdog the only meter that will work on Directv? I can not find one at a good price and they aren't cheap.
There are alot of maters that will work on D*, some very cheap analog meters for about $ 20 on up to 5-7 hundred dollars, depending on what you want to spend and do.
Very few actually tell you what sat your pointed at though, I believe the Birdog does, but don't know of any others that do.
Use the site sponsors if you want, here's one I have used (sponsor):
http://www.sadoun.com/Sat/Order/Signal-Meters.htm
Jimbo
HD Channels lost
Native mode: on or off
