Can someone please explain the differences between the 1000.2, 1000.4, and 1000+. As well as the different lnb's.
Thanks.
Thanks.
Is there anyone who knows the exact size of all the dishes? I have come up with the following dimensions from on line research. So not sure if correct.Mike, the 1000.4 is a larger dish than the 1000.2 and can also be used either on WA or EA, depending on which 3 lnb pack you use.
Good info, thanks.I don't know if the 1000.4 mount can be used with the 1000+ reflector or not. But I can tell you as one that sets up and aims his 1000.4 as often as daily, that the threaded elevation adjusting rod is a real time saver compared to the 1000.2. Because I set up so often, I replaced all of the adjusting nuts on my dish with large wingnuts for a no tools needed setup, but obviously that's not needed for conventional installations. I would never consider going back to a 1000.2, and now that the DPH42 is available, I won't need to even when we upgrade to H3's.
Limited time offer
