satellite dish pointer | SatelliteGuys.US
marklyn
95
94
Austin, Tx
If I wanted to move my Dish TV satellite to another part of my property is there an inexpensive device I can buy that helps align it for the best signal?
Enter the dishes exact coordinates of where you think you can put it (get them off Google Maps) here, select the satellite you want to aim for, and click SEARCH: DishPointer - Align your satellite dish
And with patience, even a cheap satellite signal strength meter can help you dial in the dish for the best signal without having to constantly check the receiver's signal meter.
Amazon product ASIN B01H3F8GTG
View: https://www.amazon.com/Digital-Satellite-Network-Directv-Compass/dp/B01H3F8GTG/
will this DirecTV under eave mount work
H364 loss of function
