Satellite coverage map??????? | SatelliteGuys.US
Tahoerob
385
Hayden, ID
Is there a satellite coverage map???
I might move to Idaho from Virginia & want to make sure I will not lose any channels.
you should only lose your current locals for the new locals, your regional sport network, for the new one, and depending on if you get cbshd you might have to requalify. you might also need a superdish for your new locals.
rocatman said:
Below are two website addresses. The first will allow you to determine what satellite your locals are on and if they are on a spotbeam. The second will allow you to see the spotbeam coverage. Note that Dish currently has two spotbeam satellites, Echostar-7 at 119 W and Echostar-8 at 110 W.
http://ekb.dbstalk.com/dishlist.htm
http://ekb.dbstalk.com/297
THANKS!!
This is what I need. :)
Looks like spotbeam on 110 & 2 locals on 148. I also would need 148 for HD PPV & HD Events. So for 110 & 148, does that mean a SuperDish?????
Some of that data is incorrect. I know for a fact that Philadelphia is on 110, Spotbeam 2.
811 with 282 software
811 HD:Normal
