Satellite Active transponders | SatelliteGuys.US
Xevious2K
84
Guilford, CT
I was thinking that it would be useful to have a list of all the satellite test cards. If you know of any, please list them here and I will compile a list. It would be great if we could have 1 for every satellite and add it to either a sticky post or a FAQ.
Yes, kind of. I thought that every (or at least some) satellite has a screen to identify itself. Kind of like the one you sent me for IA8.
Iceberg said:
To add satellite, go to "install" then the last one "edit satellite/tp" and add a satellite. For IA8, use the following transponder. It's a test card
11974
V
5632
sort of edited it :)
alot of satellites don't really have a "test card". There are satellites (like AMC9 & AMC6) that seem to have an active TP 24/7 but it can nver be scanned in (but if you're on the satellite it gives you a signal) but most have a channel that is 24/7
When people say SBS6, we give out the TP for ONN
When they say G3, we give out CCTV
etc
ww.global-cm.net/MPEGlistKuBandUS.html
Add the first "w"
I couldn't post the link because I am not an established member...whatever
H-11732 16.200 VETERAN'S AFFAIRS KNOWLEDGE NETWK 3
H-11805 04.580 0110 0111 RESEARCH CHANNEL
0110 0114 Audio: KEXP-FM 90.3 Seattle, WA Alternative Rock
0112 0113 UWTV-University Of Washington TV
Weird settings after doing a blind scan
Need help with setting up coolsat4000 Pro with moter.
