Satellite 2 input Reception Error SW21-3SAT | SatelliteGuys.US
KDRE
110
This is the error message Im getting on my 625 on the installation summary screen under the 119 satellite
while the 110 says reception verified SA21-3SAT
trasnponder under 110 says OK while under 119 it has a red X
Anyone know what type of problem this is.... lnb or switch or what?
anyone know if this could just be a faulty switch or not...
You will need to give us some more info on your complete config.
How many dishes?
What LNBF's on each dish?
And you are using SW-21 switch(es)?
How many receivers at your location?
Are you a NEW customer? (There is a reason for me asking this)
1 Dish I believe the Dish 500, I have the 811, and a 625, so maybe you could guess what LNBF that would be
The SW-21 is most likely being used since the error on the installation menu shows this not working or whatever its saying
Just 2 recievers as I mentioned, 811/625
I am a new customer as of last month.
I hope this helps, but if not then let me know if you need more answers.
I got the 811 to work but the 625 wont pick up a signal at all. This is the receiver giving me the error messages
A typical problem that shows like this is 9 degrees off, and you're getting 110 on the 119 "eye".
However, you will need to be more specific as do your outdoor gear as I do NOT see how you can be getting "SW21-3SAT" for the three tuners you have. That just doesn't add up.
EDIT: I'm just now reading your DUPLICATE THREAD on this problem. :mad:
Okay, this from my 625.. I get an 004 error message, tells me a problem is detected with the switch, and do a check switch
So when I do a check switch there are 2 boxes in the installation summary
box one says
Satellite Input 1
port 1 2 3
satellite X 110 X
trans X OK X
device
status RECEPTION VERIFIED
switch SW21-3SAT
box 2 says
Satellite Input 2
port 1
satellite X
trans X
device
status RECEPTION ERROR
switch NONE
then of course the bottom of the screen
SuperDish
Test Done Help
This is what I see.
Remote Question?!?
Installing a Superdish...
