Sat Signal Finder - Suggestions | SatelliteGuys.US
fire_317
69
I want to purchase a Satellite Signal Finder to take camping with me. But I also want to use it on my home system to tune it up. I have a superdish with locals at home so it needs to work with that for 105, 110 & 119. For Camping, I will just use my old Dish 500 dish with 110 & 119.
What signal finders would you suggest? Where to buy (Internet Links)?
Thanks!!
I have a "Sat Buddy" signal meter for sale. Brand new. Package has only been opened to check that the meter works. Let me know how much you're after.
I think that is a little more then what I am after.
Why do you need one?
Just turn up the sound on the receiver's meter, so you can hear it out the window of the trailer or motor home. Get the skew and elevation set correctly; the pole perfectly plumb; and swing it left or right, until the signal peaks.
Do You Think I Should???
AMC-15 on the move
