Sat 95 issues | SatelliteGuys.US
Sat 95 issues
JMSTAMU
8
Is it possible to use a 3LNB Directv dish to capture Sat 95. I want to capture Globecast channels using their receiver and a Directv receiver simultaneously using a single oval dish. I would prefer not to need to install a Globecast dish if the Directv will work for both applications. Please advise on my options.
If the phase 3 dish would work do you think Directv would use a 36" dish for the one satellite. NO IT WILL NOT WORK!!!! :)
The Phase 3 dish LNBs use curcular polarization for the transponders. The 95 degree satellite uses horizontal and vertical polarizatin (I can't remember which one) for its transponders. Therefore, they are incompatable.
Thank you for the responce. The globecast dish is a single LNB oval dish, not 36 in. Will the 36in Directv dish work for the globecast channels? Please advise.
If the above posts are correct, then you can assume:
1) The Directv DISH would work if you pointed it at 95, but this would mean moving it off the current Directv alignment of 101/110/119.
2) The Directv LNB would NOT WORK as it has a different polarization.
Yes being that it is the same satellite broadcasting the DIRECTV programming. May need to change the LNB ;)
Thanks. It means I will need to have the Globecast dish next to the Directv dish and connect the signal via 6x8 multiplexor.
Would anybody know if a regular 18in dish+single LNB will work to receive the 95 sat? Do I need an oval dish, as sold in a regular Globecast package?
Being that 95 is a mid-power sat, it needs a bigger dish and a different LNBF :no
Anyone have an update on the D100 serial interface issues?
HD Waiver Response
