D DishInstallAdam SatelliteGuys Guru Original poster Mar 27, 2011 125 0 Iowa Aug 12, 2011 #1 Can that Sat be dialed in on signal strength even if there isn't HD service on the account?
Z ZachS@DISH SatelliteGuys Pro Jun 14, 2011 1,726 159 Denver, Colorado Aug 12, 2011 #2 DishInstallAdam said: Can that Sat be dialed in on signal strength even if there isn't HD service on the account? Click to expand... Yes, you don't need HD programing in order to receive satellite 129.
D dishrich SatelliteGuys Pro Sep 8, 2003 3,424 577 Springfield, IL Aug 12, 2011 #3 You do not even need an HD receiver, since there are some QPSK SD x-ponders on it...
D DishInstallAdam SatelliteGuys Guru Original poster Mar 27, 2011 125 0 Iowa Aug 12, 2011 #4 Dish Point screen says 112 skew, 35 angle at zip 52135? Is this correct? Is Sat 129 that percise, I am at best looking at 30 on signal strength Last edited: Aug 12, 2011
Z ZachS@DISH SatelliteGuys Pro Jun 14, 2011 1,726 159 Denver, Colorado Aug 12, 2011 #5 DishInstallAdam said: Dish Point screen says 112 skew, 35 angle at zip 52135? Is this correct? Is Sat 129 that percise, I am at best looking at 30 on signal strength Click to expand... What type of dish are you using? If 1k.2 try Elevation 32 Azimuth 215 Skew 116.
harshness SatelliteGuys Master May 5, 2007 20,144 5,133 Salem, OR Aug 12, 2011 #6 We MUST know what kind of dish your using to tell you if the numbers make sense.
D DishInstallAdam SatelliteGuys Guru Original poster Mar 27, 2011 125 0 Iowa Aug 12, 2011 #7 It is a 500 with a 1k.2
boba SatelliteGuys Master Dec 12, 2003 11,350 1,036 Dorchester, TX. Aug 13, 2011 #8 DishInstallAdam said: It is a 500 with a 1k.2 Click to expand... What is a 500 with a 1000.2? Both are satellite dishes, are you doing a Western Arc with a 500 side dish for a EA satellite? Your posts as an installer leave a lot to be desired for information.
