If there is anyone who is getting this channel, could you confirm your setup with me? thanks Jason
Depends where you are located, but that Dish is probably too small, Echo's Sats are very powerful compared to the others.
For Linear FTA, an oval 30"+ is required, bigger is better.
I have no experience with Backstacked LNB, but if you set it up correctly, it should work.
I think you use the OCS LNB option vs. Standard or Universal
Iceberg, new guy here. What do you mean the bandstacked game?
lnb placement isnt the problem. I will try the data transponder. Will in enter it in as 11880?
I have no luck whatsoever! I guess I dont get wstv.
Limited time offer
