samsung sir-t451 "vs." samsung sir-ts360 | SatelliteGuys.US
jason0522
3
i'm looking for an ota hd tuner. Does anybody know the difference between the samsung sir-t451 and the sir-ts360?? Which one is better??
thanks
Jason
I personally would stay away from the t451. It just does not work well. I had one for about a month and had consistent issues with it in singal reception. I swapped it out with an LG model and have never experienced problems since.
I thought the guide was nice however when I was able to get the info.
Also, since the t451 has a QAM tuner, I thought it would do QAM on my cable system. Sure, it works,but only with QAM64, won't do QAM256 (at least the revision I had). My LG handles it all no problem.
I have no experience with the 360 model.
thanks
Jason
I NEVER had ANY problems w 451. They have a newer 1 now DTB-H260F. Cheaper $180 and smaller. Real small
Component to Composite?
What is wrong with this picture? Need help figuring out problem.
