Samsung Model: DTB-H260F | SatelliteGuys.US
hdtvtechno
I gave my HD tuner to my family since i no longer needed it
when i turned it on.. it wont display the on screen guide or the display the info screen when tune to a channel
which is weird.. it was working fine before
what could it be wrong ?
but it does tune to channel and you can watch them though.. just the guide dont popup..:(
hdtvtechno,
If I recall correctly, you must use the S-Vid, Component or HDMI outputs on it, to get those menus. (actually I'm not too sure about the S-Vid)
Could that be the problem ?
Have you ever tried yours in QAM (Cable) ?
That sure was a waste of time for me !
Have a good Day ! :)
S.W.
hdtvtechno,
If I recall correctly, you must use the S-Vid, Compnent or HDMI outputs on it, to get those menus. (actually I'm not too sure about the S-Vid)
S.W.
thats strange.. if it requires specific cable connection to get the menu..
I think th menu was working on all cable connections before..
BTW it connected with the S-video and with an OTA antenna
which side is the front
Which DTV Converter Box is the Best?
