S-video and audio switch box recommendation? | SatelliteGuys.US
n1wbd
Silent Key - RIP 1/2/2012
826
Grafton,NH
Can anyone recommend a good Svideo and audio switchbox so I can switch between my Geosatpro and dish network receivers I only have one set of inputs on my Proscan analog TV.
Bob
IF there is a Rat Shack near you I know they carry some. I use to have an old 4x1 switch but no S-Video (but I dont think svideo was even used then) :p
I checked the catalog and dont see them but I know they have some 4 input 1 output ones there....maybe on clearance too
I use a Psyclone PSC-01 for my analog video and audio switching. The unit can do component, S-Video, composite, and even TOSLink optical digital audio and RJ-45 network switching. It is a 4 X 1 device. They are relatively expensive new, but can be had much cheaper on E-Bay. These are full-featured switches, and include remote control capability as well as programmable labels for each input with a backlit LCD display that shows which device is being switched.
Looking for VS2000 platinum/lite software
Openbox Remote
