rv direct tv antenna | SatelliteGuys.US
fredfreeloader
nowhere
going to take one of my receivers along on camping trips.....whats the best antenna to use and still get my local channels from home. tia
? The same dish you have now.. however you may not get your locals depending on how far away to go camping.
IF your using a 5 LNB set up and are comfortable setting it up and have room to store it ... thats the one I would go with, you'll get everything you currently do.
Otherwise go back to a slightly smaller 3 LNB set up, old style, or you can venture up to a NEW version 3 lnb set up.
All depends on what you can set up easily enough.
You will get your locals till you go outside of the spotbeam for your area.
Jimbo
There are two key things we need to know before answering accurately. What's your zip code, and are you looking to receive just SD signals or HD signals also?
TECHNICIAN DELETED ALL MY DVRS PROGRAMS
Oh.. My.. Deity... Directv is expensive!
