RTV on AMC9 | SatelliteGuys.US
RTV on AMC9
Yep it has not went anywhere.
yep.....What receiver are you using? Try to put in in manually.
That doesn't make sense. It's coming in great on a 90cm Fortec here.
3F is a little stronger (71% Q) than RTV @ 63-67% .
Both blind scanned in no problem.
I've always seen it on 11735...symbol rate fluctuates between 4440 and 4444 depending on blind scan but its there
I finally locked RTV @11741 on the Micro HD. It did not blind scan in...maybe cuz 11735 was already in the TP list and the numbers are too close. Was sure perplexed for awhile as to why I could lock 72W and 87W but not 83W, so glad to see this post.
which firm ware to use on your fta receiver
Best HD FTA PVR?
